Hello.
I have just purchased a 2000w inverter. Am I correct in saying that the wiring is positive to positive battery terminal and the negative to the negative terminal on my shunt? Thanks in advance
Hello.
The negative of the inverter connects to the system/ load negative terminal of the shunt. Positive to the battery positive. Do not forget a fuse as per the manual.
