Off-grid installation ( Inverter Multiplus-II 48/5000/70-50, SmartSolar Charger MPPT 150/60, CerboGx, 2 batteries Pylontech US5000 )
When disconnecting the BMS cable between the battery bank and the Cerbo, the charger apparently “loses its mind,” causing the inverter to display a low-battery alarm and then disconnect, even though the voltage of the connected battery has never dropped below 49.5 volts. VRM Dashboard shows a virtual drop till 30,74 volts.
I think this software needs to be improved. It is necessary to implement the option of disconnecting the BMS through VictronConnect without causing a power interruption.
(Cerbo Charger conected by VE.Direct and Cerbo Multiplus by VE.bus)
