Cannot charge after Smartlithium battery got deeply discharged
I use a MultiPlus Compact with a 330ah smart lithium battery in a camper van. The battery got deeply discharged recently. The low voltage warning popped up, and the Victron Connect app shows that discharge has been disabled.
So I plugged in shore power. But the battery doesn’t start charging. However, when I connect a blue smart charger directly to the battery. The charger shows that it is charging. This seems to indicate that the battery itself is functioning.
I would like to know why charging didn’t start with the MuiltiPlus when I plug in to AC power source after a “deep” discharge.
Thank you.
Do you have fuses between the inverter and battery?
Is this the inverter itself? Or the battery? Is it a victron battery? What is controlling the inverter - (BMS to inverter connection?)
There is one. I confirmed that the fuse is intact.
It is a Victron Smart Lithium battery. The low voltage warning is from the battery. It also says “discharging disabled” on Victron Connect app.
I have a network cable between BMS and the inverter. So I think that the inverter is controlled by BMS.
What bms do you have exactly on the battery? Victron have a few options
What BMS.
Do you have the “mains detector” fitted to the multi compact?
I have VE.Bus BMS V2.
I don’t know what “mains detector” is. But if this is a separate piece of device, I doubt that I have it.
I also want to add that this system has been working as expected prior to the battery deep discharge.
Yes. We understand that.
Basically the system ended up in a locked out condition.
It is off. There is no way for it to know you switched on mains power.
You need the mains detector as mentioned by water_rat
A mains detector and a short RJ45 UTP cable ship together with the VE.Bus BMS V2. These are needed for mains detection once the inverter/charger has been turned off by the BMS.
The mains detector is required if you have a metal cased multi compact.
If you have the newer multi compact apparently the mains detector is not required.
From the BMS V2 manual. This happened with my test bench system.
“Q2: The batteries are empty, and the inverter/charger will not start to charge; how to get the system up and running again?
Connect a small battery charger, for example, a 5A charger, and wait for the battery voltage to get back up to 12, 24 or 48V (depending on the system voltage).”
Thank you, guys. As a few have pointed out:
  1. I should have installed main detector to prevent situation like this.
  2. Without main detector, using a separate method to charge the battery will get out of this state.
