Integrate Solaredge inverter into Cerbo
I have a question.
I would like to add my solaredge inverter (2x) via Modbus. These inverters are now linked to Homeassistant. I want to remove them from here because you can only address the inverters once on the Modbus-TCP. Is it possible to link them via Modbus-tcp?
I have added the inverters manually in the Cerbo. But it can’t find them.
Can you give me a good hint.
Greetings
Palermo
Maybe this helps?
https://community.victronenergy.com/t/victron-mpiis-with-solaredge-and-2-batteries/23313/5
