Hi!
So, I’ve searched and searched and failed just as many times. I find my self to be a technical guy but this is a little bit of a new world to me.
I’ve just built myself a few 4S packs, with Daly BMSes, peaking at 16,8V.
I want to add this to my boat. The boat today has an old marine diesel with a 90-100A alternator.
I have a start battery and a battery bank for the fun stuff, separated by one of those relays that cuts off the start battery once the engine is off.
My plan was to swap the battery bank with an Orion XS fronting my 16,8V packs. So far so good, and I thought I could use that as a power supply once the engine is off, but then I learnt that the XS acts charger OR converter.
So, if I do what I just described, and charge my pack using the fine features of the XS, how do I get power back to my “comsumer circuit” so to say? Do I need a second XS acting as power supply, or a cheaper TR? If so, would that result in power to my stuff from the unit once the engine is off? Also, is there a problem with that config when the engine actually is running?
So, what I want to achieve, is to have 12V out of my Li-Ion pack, at all times pretty much, while it’s also being charged when the engine is running.
Solar panels shouldn’t be an issue since I can just add an SmartSolar MPPT directly to the batteriets I guess?
Thanks all, for whatever light this community night shed on me ![]()
