Dear members of the community, I have a question concerning the venus gx inside the inverter is it replaceable once it is discharged?
What do you mean by “gx inside … is discharged” ?
Yes, the GX board is a standalone and therefore replaceable item.
You can see it in the manual at the page 26…
Or you are referring to the operating system ?
Are you referring to the nano pi onboard battery?
Thank you, for your prompt reply, then how can I know if it is discharged friend, as the manual does not explain?
With a Multimeter i guess? Same way you would test a button battery.
I have never heard of one needing to be changed though. So your request (to me anyway) is a little unusual.
Ok, thanks.
The internal GX device will get it’s power from the Multi’s battery, therefore should not just be ‘discharged’, thouhg it may have some internal backup that could go flat.
If the GX is not working, then it would need replacing.
Thank you.
