I am attempting to set up a split phase system in an rv using both inverters with same firmware update. I am getting error code 25 incompatible firmware versions. Is there a workaround or do I need exactly the same models? they seem so close… Same output ratting just different transfer pass thru
peripheral equipment Mk3 interface, cerbo GX , GX 50, solar charge controller 150/100, 1600 w solar and 600 ah Li bank
Thank you in advance.
