Hello everyone!
I am gravitating towards a MultiPlus 2 48/3000 and a 48V 100 Ah battery to set up a small home storage for an existing AC-coupled PV.
The place where I would like to install the MultiPlus 2 and the battery have no direct access to the breaker box and grid connection point. However, I could connect the energy meter directly to a Wifi router via a LAN cable or via Wifi.
What would be the simplest way (cheapest, fewest devices), to add a 3-phase energy meter that can interact directly with the MultiPlus II via Wifi?
- I have read about the Shelly Pro 3EM, but apparently it’s sluggish update rate can lead to oscillations in the inverter output/input.
- I have also found the EM24 Ethernet meter, but read that it supports only 5 A per phase.
