My DIY off-grid system I am interested with this requirement and form with this configuration:
REQ:
- Provide 6KW 240V AC
- Provide 6KW 120V AC
CONFIGURATION:
- |2x MP-II (Split-Phase)|6kVA (240V)|Standard North American split-phase.|
- |+ 3rd MP-II (Parallel)|+3kVA (120V)|Extra 120V circuits (or 240V if phased correctly).|
The AC wiring are
- AC Output Wiring:
- Split-Phase Pair (Inverters 1 & 2):
- Inverter 1 (Master) L1 → Load Panel L1
- Inverter 2 (Slave) L2 → Load Panel L2
- Neutral (N) → Shared between both inverters
- Third Inverter (Single-Phase):
- L1 → combine with L1/L2 on the Load Panel).
B. Victron Configuration (Using VE.Config or VictronConnect)
- Configure Split-Phase Pair (Inverters 1 & 2):
- Inverter 1: Set as “Split-Phase Master (120/240V)”.
- Inverter 2: Set as “Split-Phase Slave”.
- Configure Third Inverter (Parallel Single-Phase):
- Set as “Parallel (Single-Phase)” → Assign to L1 or L2 (depending on need).
- Adjust current sharing in settings.
- PowerAssist & Current Limits:
- Set max AC input current (e.g., 50A for generator support).
- Enable “Weak AC Input” if using a generator.
QUESTIONS:
- A tech-support mentioned the Multiplus units must be within 6 months of manufacturing (Same SN) to allow the sync. Is this a MUST requirement?
- Combining 3rd Inverter L1 to an L2 (120V) as parallel in the same Panel is correct?
- Any special wiring required?
