How to configure Multiplus II 48/3000/120 Split phase system to charge with a generator
Has anyone successfully configured an off grid Victron Multiplus II 48V/120V/3000VA, split-phase system with a generator to charge their battery?
I have 2 x MPII 48V/3000VA setup as Split-phase 220/240V. My solar MPPT charged the battery but during cloudy weather, I need the generator to charge the battery. My small 120V 3KW genie input to the MPII Master AC input 1, its power will get pass through to L1 but it would not charge the battery. Both MPII run as Inverter+Charger, I have 4KW Solar Victron SmartSolar MPPT charger charging the 48V LiFePO4. My CerboGX report the Generator is STOP and no current flow to the system? I enabled both MPII charger with Weak AC current, Disabled voltage Sense. Still nothing, the MPII charger did not work. What am I missing? Thanks
