Home assistant integration via MQTT
Hi all,
I’ve recently been working on Home Assistant integration , and although there is now a HA victron integration, it does not allow the use of mosquitto and so the HA entities connect to the cerbo gx MQTT broker directly rather than caching values locally. Additionally I wanted more control over the sensors/selects/numbers (things like text, number rangers, step size, default values etc). So, for information purposes I’ve shared my victron yaml. It may be useful to others doing a similar thing. HTH. Derek.
Victron.yaml
