Hi to all , i not found a method for reset complete history from smartshunt 300A . I move this device to another battery , but the history , contains a old history and i’can’t remove it. !!
thank you but i tried this .. i don’t have resolved the proble , the history , ampere product and cycle are present .
7.5.9. Reset to defaults
Does not reset history.
Resetting history at the bottom of the history tab does.
Do it a few times if it doesn’t clear.
Hello! Thank you so much for your help. I did tests on a 50Ah and 51.20V Lifepo4 battery. I set the SmartShunt with the charge voltage, i.e. the bulk, when I load the battery, for example 56.3V, after the current tail dropped to 4%. Then I moved the shunt to a new 51.20V and 200A battery. I tried to delete the stored data, but they still remain.
I do not have that screen any longer. That’s one that is gone.
Found a reset. Have tried it 3 times. No change. Nothing will reset.
I wanted to know why the smartshunt if set for example 55.20 v queue current e.g. 3% for 1 minute , the SOC activates 100% always before . I was asking if the first time I have to intervene manually e.g. when the battery reaches 55.20v and I see that it absorbs less than 3% of current I have to press sync SOC or should he do it manually ?
From the image only 0.2 % is missing but he and in the vicinity of reporting 100% despite the fact that I have set at 55.20 v and 1 minute of waiting for the current to fall to less than 3%.
