Storing shunt history
I’m adding another battery to the system and will be disconnecting the smart shunt, will I lose the history? If so, is there a way to save it?
Hi @GoatTracker,
The SmartShunt history will survive being disconnected.
There is a variable for what the SmartShunt should set the current battery state of charge to when it is disconnected.
You can choose if it maintains the same, goes to 100%, or is set to – until it can re-calibrate itself on a full recharge.
