GUI V2: Solaryield / Solarertrag should by named Solarpower / Solarleistung
Hello everyone!
power is not the same as yield
In the new GUI, the box at the bottom left displays the sum of the power outputs of the solar chargers and AC inverters. It’s shown in watts or kW. However, the term “solar yield” is incorrect. It’s power, not yield. The German translation in the GUI says: “Solarertrag” and should be “Solarleistung”.
Also: The same applies to the vrm web portal, for example, to the “System - PV Yield” widget. Each point on the curve represents the power in watts, but yield is to measured in watt-hours.
In the dashboard it is better solved, because there it says “PV inverter” or “PV-Wechselrichter”
General: Yield is only measured in watt-hours (kWh, Wh); otherwise, it’s power or load, measured in watt.
Regards, Manfred
Same issue there:
