Hello everyone!
@mpvader
@Matthijs Vader
This problem isn’t new; I think it’s been there since the beginning of GUI V2.
In the new GUI, the box at the bottom left displays the sum of the power outputs of the solar chargers and AC inverters. It’s shown in watts or kW. However, the term “solar yield” is incorrect. It’s power, not yield.
Also: The same applies, for example, to the “System - PV Yield” widget. Each point on the curve represents the power in watts, and the area below it corresponds to the yield in watt-hours.
General: Yield is only measured in watt-hours (kWh, Wh); otherwise, it’s power or load.
Regards, Manfred
