Can Growatt ARK 2.5H-A1 HV batteries with HVC 60050-A1 BMS communicate with a Victron Quattro or MultiPlus via BMS-CAN through a Cerbo GX? Or is there some other way to get ARK HV batteries to talk to a 30kw Victron Inverter?
Thanks.
Lars
Thanks.
Lars
Thats a high-voltage (HV) battery, none of the current systems is capable of it’s voltage range, and its comms are not supported.
Are you sure you don’t mean a different model that is 52V nominal?
As an unsupported battery type, you really need to ask the manufacturer who is responsible for any support.
General information about batteries that are not on above list
Many additional 3rd party batteries are also compatible with Victron, and are recommended by local dealers.
Using these batteries is permitted under warranty, and they will require additional information and support from a local supplier.
