I have 3 kinds of installs with Cerbo where the “grid lost” alarm doesn’t work. Can you please fix it in future versions of Venus and VRM? @guystewart
Setup where there is Phoenix Smart IP43 Charger 12|30 (1+1) connected to Cerbo via VE.Direct
Telco site with unreliable AC on site with DC only loads connected to a battery and Orion, no inverter
Setup where there is Carlo Gavazzi EM connected to Cerbo, set as Grid Meter with 3rd party inverter
Setup where there is Carlo Gavazzi EM connected to Cerbo, set as Grid Meter with no inverter - only used to monitor grid consumption and PV Inverter production
Just FYI the interface is built around an inverter charger like the multi or Quattro. Without one it won’t behave as expected. This is documented for non-victron systems.
There are some improvements pending, but using an EM to get a third party device into VRM is never going to be a supported config.
Sure… out of the 3 mentioned, the first one is really the one that interests me the most - it’s all-Victron system, just no inverter since there is no need for it… and it would still be useful to get “Grid lost” alarm as the Phoenix charger is connected to grid.
I would like some more love for DC only or AC->DC systems … for example: no need to display “inverter box” and “AC loads” box in such systems - both in VRM and GUI - it just takes space with no value whatsoever for end user
while surely not as popular as systems with inverters, I think such systems are very common - telco, campers, marine and I feel they are bit forgotten in the UI implementations even thou Victron sells bunch of DC equipment that connects to Cerbo via VE.Can or VE.Direct
+1 on Peter comments regarding the UI. I have 1 solar installation in my boat with the following Victron devices:
Phoenix Smart IP43
MPTT 150/60
Battery Monitor BMV 700
Cerbo GX MK2
I’d like to know when there is no grid connection, so I’m trying to add some alarms on the Phoenix charger without success. The device keeps the last value when it’s disconnected from the grid so the alarm does not trigger anything
Is there any way to setup an alarm to know when there is no power to the Phoenix Smart?
Hi @nickdb any answer to my previuos message? It seems easy to detect when the Phoenix Smart IP43 has no power or it’s not sending data to the Cerbo, isn’t it?
How could I setup an alarm to know when there is no Poer connected to the Phoenix Smart?
