Hello All,
I’m used to working in the Victron Configure app, but logging into VRM, I see two settings that sound the same to me… What am I missing?
Is “Input Current Limit” on the DC side?
Thanks!
These settings are spelled out in detail in manuals for GX and Venus devices.
Just re-read through the GX manual, and I’m still confused… why I’m asking.
The manual is ambiguous, as far as I can tell. I’m sure obvious to someone who’s lived it…
Grid is what is measured from your grid energy meter.
Input is what is measured on the AC-IN of your Victron system.
This is useful for example when you have loads connected on the AC-IN side and prevents your Victron system from overloading your Grid connection.
Sorry… still thinking this through…
I don’t have a grid energy meter, aside from the utility meter–not connected to anything Victron.
This is true for me.
So I don’t understand the distinction if AC Input 1 is Grid… Should I always use the same value in “Grid current limit” and “Input current limit”?
For the “Overruled by remote” … as I understand this, it allows someone in VRM to change the values from what is set in VE Configure, right?
Thanks
