Hello, I use a GlobalLink 520 at home in Germany, and it works perfectly there. Now I’m in Italy, and the SIM card should be roaming. Italy is supposedly supported by 1NCE. No matter where I am in Italy, the GlobalLink won’t connect. Do I perhaps need a different APN? Currently, the APN is iot.1nce.net. Can anyone help me? Thank you.
On this map (link is from the GlobalLink manual) Italy is gray:
Ok… thanks, thats may be the reason… ![]()
