I’m pretty sure the answer is yes but I’m spending someone else’s money so really need to be sure! I just completed a 36V setup with a Globallink 520. The documentation says it has two VE Connect inputs and can connect to two devices including … ‘a MPPT Solar Charge Controller’. Can it connect to, and report on two different smartsolar chargers?
Yes you can. And if the MPPT chargers are smartsolar and not blue solar, you can also connect up to 10 devices via Bluetooth.
Brilliant, thank you.
