Post #3 bill of material
Work in progress
main power distrubtion cabinet
- cabinet
Hager ZB33S 1100x800x205mm, 3 fields - 4p manual 1-0-2 transfer switch
Kraus&Naimer Netz-Umschalter KA63B. T904.VE2.F437 - MP2 5k ACin/out1/out2 line protections 50A
3+N Hager MBN650, today I would use 4p and no 3p+N - distribution block
Weidmüller 1562140000 WPD 501 2X25/2X16 1XGN/3XGY/1XBL - main switch blockable
Hager SH363S 3polig 63A - 4p switch for coubling into vertical power chains
Hager SBN463 (63A is chaeper than 50A) - vertical phase rail connecting 3 rows
Hager KCF668S 3p+N 3 rows - horizontal phase rail to connect RCD/breaker
Hager KDS463AT 12 Mod. 63A L1L2L3N - for each single-phase 16A load circuit RCD/breaker combi
Hager ADS916D FI/LS-Schalter 1P+N 6kA B16A 0, 03A A QC&QB - for each 3-phase 16A load circuite RCD/breaker combi
Hager ADM416QC 4P 6kA B-16A 30mA Typ A QC/QB
By intention I will not make any suggestion on surge protection or grid meter field. This depends heavily on local regulations and need a certified electricion.
cabinet mapping 3xMP2 to 3phase
- cabinet Hager VA36CN + door Hager VA36T
- 3x distribution blocks
(see Weidmüller at main power distribution board)
AC cable
- Lapp Ölflex Cassic 110 3g10 and 5g10 for 50A
MP2 external fan
- 80mm fan Acrtic P8 PWM PST
- fan speed controler https://de.aliexpress.com/item/1005006994739710.html
- cabel zip ties
- 48V to 12V converter Meanwell DDR-15L-12 or DDR-60L-12
(the “L”-variant accepts 48+V)
Lynx Fuse Monitoring
- ft232h USB-i2c adapter: https://de.aliexpress.com/item/1005006984824882.html
- RJ11 cable
- 2x 10k ohm resistirs as pull-up
- software: GitHub - twam/dbus-lynx-distributor: Plugin for Venus OS to readout Lynx Distributor with Lynx Smart BMS
DC fuses, cable, lugs
- Adler EF3 200A/50,000A
https://www.adlerelectric.com/de/product/EF3-de_DE/ - sources:
– @Meine_Energiewende https://rayotech.de/
– ECS: EF3 SICHERUNG 200V DC IR bis 50kA BAUGR 77x22mm - Lynx intervonnect NSGAFÖU 95qmm
- Lugs: Klauke „sg“-varinants. These are narrow and fit into Lynx
Different 70qmm cable lugs. Only the left one Klauke KL-70-8-SG fits into Lynx with fuses.
