Piotr
82
GbbOptimizer for hybryd inverters: https://gbboptimizer.gbbsoft.pl/
Version 16.14
Piotr
83
Version 16.16
- Add support for Supla meters as an alternative source of PV production data
Piotr
84
GbbOptimizer: hybryd inverters optimizer: https://gbboptimizer.gbbsoft.pl/
Version 17.01
- Loads Profile: added a table to artificially increase/decrease the calculated Loads profile for given hours/days of the week.
Piotr
85
Version 17.02
- Add support for SolarEdge system as an additions source of PV when SolarEdge inverter is connected in paraller to main inverter.
Piotr
86
Version 17.03
- IoT: Added ability to write a C# function that determines whether to turn a switch on or off
Piotr
87
Version 17.04
- Optimizer: ability to automatically increase the Minimum SOC if the planned PV is less than the specified number
Piotr
88
Version 17.05
- ExtraLoads: AutoAdd: Allows to define repetitive every x days ExtraLoads (e.g. boiler) for which there are no counters
Piotr
89
Version 17.06
- Discharging: added the ability to indicate the hours when the inverter is to be disconnected from the grid (Deye, Victron)
Piotr
90
Version 17.07
- IoT: Ability to turn on devices at x hours with the cheapest/most expensive purchase/sale prices
Piotr
91
Version 17.08
- ExtraLoads: add more Generic columns: from 3 to 6
- ExtraLoads: names and colors of EV and HP columns can be changed
Piotr
92
Version 17.09
- EV Charging: Added a test to see if EV charging is in progress to disable battery charging/discharging
Piotr
93
Version 18.00
- Wind Turbine: Added Wind Turbine production forecasting based on wind speed forecast and taking it into account in the Optimizer work
Piotr
94
Version 18.01
- IoT: Possibility to turn on devices (e.g. watering) if there is no y mm (or there is y mm) rain within x hours
Piotr
95
Version 18.02
- Added the ability to use IoT meters to measure energy from and to the grid
Piotr
96
Version 18.03
- Prices: Added the option to specify that a given day (e.g. a holiday) is to be treated as another day of the week (e.g. Sunday)
Piotr
97
Version 18.04
- Optimizer: new option ‘After how many days to hold 3x100% again from the previous 3x100%?’
Piotr
98
Version 18.05
- New message on top of Battery Forecast if 3x100% is planned for today or tomorrow
Piotr
99
Version 18.06
- IoT: Possibility to turn on devices (e.g. watering) if there is no y mm (or there is y mm) rain within x hours but in past
- Victron: Possibility to turn off inverter “When nothing to do”
Piotr
100
Version 18.07
- Added the ability to enter ‘Inverter’s self-consumption’, which is added to Loads every hour
Piotr
101
Version 18.08
- Victron: added the ability to change ‘Maximum feed-in’ to 0 when sales price <0
