GbbOptimizer (a professional DESS alternative)
GbbOptimizer for hybryd inverters: https://gbboptimizer.gbbsoft.pl/
Version 14.32
  • Optimizer based on prices: extended the “Try not to import from the grid” option with the ability to specify a purchase price above which the option work
Version 14.33
  • New condition to switch on/off external devices: based on next 24h PV forecast
Version 15.0
  • Start of new promotion for program recommendations in the Installer menu! Recommended Users can receive a discount of 10% during first year, and Recommending Users can receive a discount of 10% on Recommended Persons’ deposits.
Version 15.1
  • New price source: NordPool
Version 15.2
  • IoT: New condition to switch IoT devices based on ‘Nothing to do’ condition of inverter
Version 15.3
  • menu Gain/Profits: add column ‘Energy cost’ (:=Purchase Amount - Sales Amount). Also added information in the Battery Forecast menu above the charts.
Version 15.4
  • Victron: Relay1/2 outputs added to IoT system, allowing them to be turned on and off under different conditions (like in Tuya or Supla)
Version 15.6
  • Optimizer based on prices: Special MinSOC for optimizer, different than for whole system.
Version 15.7
Version 16.2
  • Optimizer based on prices: new option: Block go above MaxSOC (via discharging to MaxSOC)
Version 16.3
  • Optimizer based on prices: new option: Charge battery from grid (means: do not charge)
Version 16.5
  • New condition for controlling IoT devices: min/max/avg outside temperature within x hours - enables controlling devices based on the forecasted temperature.
Version 16.6
Version 16.7
  • New price-based optimizer option: Do not import power from the grid when the outside temperature is higher than X (to protect against overheating)
Current set of optimizer options:
Version 16.10
  • Month statistics: new columns: Min/Max Daily FromGrid/ToGrid/Consumptions/PV
Version 16.11
  • New condition for controlling IoT devices: min/max/avg Grid Voltage (V) - enables controlling devices based on present and absent of grid.
Version 16.12
  • New tool: AutoAdd: Allows to define repetitive ExtraLoads (e.g. boiler) for which there are no counters
Version 16.13
  • New condition for controlling IoT devices: present or absent of Meteo Warnings
