GbbOptimizer (a professional DESS alternative)
GbbOptimizer: hybryd inverters optimizer: https://gbboptimizer.gbbsoft.pl/
Version 18.09
  • Prices: added fixed month costs (brutto) to split for all hour in month
Version 18.10
  • EV: New module for automatic EV charging when the appropriate conditions are met
Version 18.11
  • EV: added support for Easee charges
Version 18.12
  • In option “Don’t sell more than non-corrected forecasted PV production in last x h” you can select more than 24h (up to 48h)
  • New option to manually force 3x100 today with new API by mqtt. Option is automatically reset after 3x100. (HomeAssistant can force 3x100 based on BMS information)
Version 18.13
  • IoT Meters: ability to detect consumption to automatically insert ExtraLoads in the following hours (e.g. boiler)
Version 18.14
  • EV: added integration with evcc.io system for EV chargers control
Version 18.15
  • Charge: new parameters for charging from grid
Version 18.16
  • Battery Balancing: New (advanced) options
Version 18.17
  • New optimizer option added to make life easier for users: Don’t discharge battery if sales price is less then X
Version 18.18
  • New module to heat inverter when cold outside
Version 18.19
  • Different forecast/prices periods: 24h, to end of next day, 36h, 48h
Version 18.20
  • HP: Special option for people who switch from HP to gas/coal in winter.
Version 18.21
  • New option for winter: “Increase Max battery SOC by (pp.)” (if PV Forecast less then (kW))
Version 18.22
  • Added the ability to specify the start hour of the 24-hour period in which the program finds the lowest/highest price
Version 18.24
  • IoT: data collected from meters can be corrected by the entered multiplier
Version 18.25
  • Tesla: In AutoCharging, dynamic setting of the required number of minimum price hours has been added, depending on the SOC level of the connected cars
Version 18.26
  • EV: Added support for Volvo electric cars: the program detects whether it is connected, whether it is at the right distance from the PV and, based on the SOC level, can find the appropriate number of hours with the cheapest energy to charge the car’s battery.
Version 18.27
Version 18.28
  • Wind Turbine: the ability to reduce the forecast for specific wind directions has been added to the Wind Turbine settings (the impact of natural obstacles on the forecast)
Version 18.29
  • Added the ability to define multiple price definitions that change throughout the year
