GbbOptimizer (a professional DESS alternative)
Version 14.18 https://gbboptimizer.gbbsoft.pl/
  • Non-Victron plants (eg. Deye): add ability to import data from Victron EV Charger (from VRM)
The program’s advanced pricing system is based on the import of dynamic prices from various sources and the addition of tabulated constants.
Source of dynamic prices is one of following:
Tables are based on hour and weekday:
Version 14.19 https://gbboptimizer.gbbsoft.pl/
  • IoT: New condition to switch IoT devices based on Corrected PV Forecast.
Optimizer options:
GbbOptimizer for hybryd inverters
Version 14.20 https://gbboptimizer.gbbsoft.pl/
  • Information about the maximum allowed power from the grid has been added so that the optimizer is aware of this limitation when, for example, the battery is being charged and the EV is being charged at the same time
Version 14.21 https://gbboptimizer.gbbsoft.pl/
  • menu PV Forecast: new options “Snow on Panel”
Version 14.22 https://gbboptimizer.gbbsoft.pl/
  • Optimizer based on Prices: new option: Don’t use battery (charge nor discharge) if purchase price is less then X. Useful if you want to leave free electricity in batteries for more expensive tariffs.
Version 14.23 https://gbboptimizer.gbbsoft.pl/
  • On Plants menu Dark Mode can be switched on
Version 14.24 https://gbboptimizer.gbbsoft.pl/
  • Added support for dynamic transport prices (PL Tauron G14dynamic) including data import from PSE and the ability to manually correct prices.
Version 14.24.1 https://gbboptimizer.gbbsoft.pl/
  • Optimizer based on prices: tries to fill the batteries for a period where there are no buy and sell prices yet
:cry:
Version 14.25 https://gbboptimizer.gbbsoft.pl/
  • Input/Charge Limits: can be defined by weekdays (important for Swedish “Power Tariffs”)
Version 14.26 https://gbboptimizer.gbbsoft.pl/
  • Optimizer based on Prices: new option: Don’t charge battery if purchase price is over
In GbbOptimizer you can define additional transport costs per hour per weeday:
Version 14.27
  • For those who get a lot from and to the grid, the “Round trip efficiency (RTE)” indicator has been added to Profits in “monthly totals”
Version 14.28
  • Extension of the possibility of limiting the sending of electricity to the grid by a limit in kWh
In GbbOptimizer is special option to charge battery to 100% and keep it at 100% for 2-3 hours:
GbbOptimizer for hybryd inverters: https://gbboptimizer.gbbsoft.pl/
Version 14.29
  • If you import data about the power of the Heat Pump, the program can automatically calculate the Heat Pump parameters to forecast the required power in the future.
Version 14.31
  • Added ability to setup own name and color for Generic1 and Generic2
GbbOptimizer has special options for EV charging:
If you provide information about upcoming EV charging, the optimizer will set the inverter accordingly.
