I have. Digital Multi Control on a multiplus with a VE.Bus Smart Dongle. The DMC works normally, but when I shut it off, all the LEDs flash, sometimes for an hour or more. I’m thinking it may be the thermocouple on the VE.Bus has failed?
Hi @Dauerr,
Have you used the Victron Toolkit app to identify the exact code of the LEDs?
Thanks for the reply. I’ve never used the Toolkit, but it seems now is the time. I did look through the manual for the toolkit and looked at a more expanded list of error codes and all flashing LEDs were not listed.
If you can record an LED code that is not available in the toolkit app, I can document and add it.
