Any clues how to update firmware without Bluetooth?
If there is a VE-Direct socket, then that can also be used for a firmware update.
Even easier, I just selected Firmware update on the raspberry pi it’s connected to via VE.Bus and a USB-VE.Bus Mk3 adapter and it just did it. Now working in a parallel setup of two inverters with identical firmware versions. Thanks.
