I have several problems here. First, when I select my device using the VictronConnect Windows App, it immediately tells me that my firmware is incompatible. I have v408 and I need v415 or higher. I click OK I do see a screen showing input, output, battery voltages and all the other information I’d expect. What I bought this for is so I could correct the settings that as far as I can tell are incorrect in Absorption and Float voltages etc. If I try to enable settings it says I need a password which I can get from training?
So, two things: how can I update the firmware? Second, how can I access settings? That’s why I bought this adapter.
When I use VEFlash for Wiindows it just asks me for the file. I’m trying to download from professional.victronenergy.com but the entire site is not responding.
I see hundreds of files there. I don’t know which one. I see no 7 digit number on the system board, but there are three stickers which all have S/N Product etc but they are much longer. Sorry but I’m unclear which one to use.
VEFlash for windows won’t connect via the com: port I configured, which does work fine for VEConfigure for Windows. I looked for VEFlash for Android because my phone will connect via usb-ve.bus dongle. Can’t find that. My phone connects every time but complains initially about the firmware version being too low and then it displays and I configured the multi-plus just fine in that state. But I feel it would be best to have the latest and greatest updates for this unit.
i did mine today for the first time .i found out i have a very early firmware 142 and computer would not connect .but i updated the usb driver and now it connects ok. but if i try with my phone it says wrong firmware. i think i need to update the firmware to above 200 .i believe my inverter can only upgrade to the 200 firmware any higher will not work .
but for now im happy it connects fine on the compute r
