Feature request: EM24 Ethernet grid meter, phase to phase voltage monitor
Hi, just run into a unpleasant situation where the grid malfunctioned, no voltage (or shorted somwhere on the way to me) between 2 phases.
Fronius reported an error but nothing clear.
Looking on the VRM, the grid meter is showing ~235V on all phases.
Had to go on site and cycle through EM24 menu to see that L1-L3 voltage is zero, L1-L2 - 405V, L2-L3 - 409V.
It would be great to also have access to other parameters measured by EM24, especially phase to phase voltage. Tried custom widget on VRM but no such data is exposed.
Not sure if this is just not exposed in VRM in general (which seems to be the case, from a quick look), a VM-3P75CT meter shows those values via the Home Assistant Integration via HACS.
The Carlo Gavazzi software show all data available on meter display, over the same ethernet connection.
It might only be a matter of reading extra registers/addresses through Venus OS.
