Fail to access cerbo GX by ssh client
Hello, lm trying to using ssh client to access cerbo device. I got the superuser permission, Is my IP address setting wrong?
Use your IP under ethernet settings, not the remote support IP.
or look on VRM ‘diagnostics’ your install number where the stars are and look for local IP:
vrm.victronenergy.com /installation/*****/diagnostics
These are my settings:
username: root
Password: (What you set on the GX)
Thanks for answer.
I didn’t plug ethernet cable to my device, if I set a hotspot and connect it with GX, it’s possible for me to access GX by ssh client.
Never mind, I set the hotspot’s ip address then access success,thanks :+1:
Glad you sorted it, I just updated my answer to help others.
