Hi after charging the wallbox, the car stays connected but if I turn on remote heating in the car the wallbox turns off and says waiting for start. I have the wallbox settings on manual and contactor contacts enabled and calibration done so is the fault on the car side that it disconnects or the wallbox? Car is skoda enyaq
Not all the cars are allowing consuming from the grid for heating. Not sure about Skoda.
Aha ok I’ll try to check
I figured out where the error was on my side
, I had set the maximum charging power to 4.2 kW and when I turned on the heater at one point it exceeded that value, the wallbox disconnected so I set the charging to 11 kW and then it took power from the wallbox instead of the car battery.
nice, so problem solved!
