EVCS new cable not working
I have 5m original Audi cable 3-phase 480V/20kW and it working fine with my Victron EVSC, also one 5m 1-phase Defa eConnect cable working fine also in 1-phase setup in my other Victron EVSC location.
Now I buy longer 7,5 meter 3-phase Defa eConnect cable and it is not working even I try to CP calibration to it.
When it is connected to EVCS and I connect it to car, few second charging port show green light, then it goes to red and car send message charging failed. CP calibration doesn’t make any changes to that.
Any ideas, what goes wrong, why CP calibration not work and help with this cable?
Hello @Kallu.
Have you tried your new cable with another EV charger?
Are you sure that the new cable is ok?
If so, we can check your EVCS remotely.
Yes, I already try it also with my another Victron EVCS, same result.
I return this cable and order new from different manufacture, lets see how it works.
It is possible that cable is not ok and that’s why not communicate right way with car.
Thanks,
\ Mika
