I seem to have en issue with my EV Charger. Whenever my wife’s Fiat 500e is done charging the contactor for the three phase lines intermittently activates and deactivates. See this movie: relay_clicking.mov
Strangely enough, this does not happen with my Tesla Model 3.
I found a similar thread on the old community forum, that states that this is a calibration issue. However, it is my understanding that the CP line calibration is now done automatically (the manual calibration button is gone at least). The EV Charger is running firmware v2.05.
Also, I have measured the CP signal with my oscilloscope and the Fiat 500e does it by the book. Nothing to put a finger on here. It is fully charged and not requesting charge, so the voltage of the duty cycle should be ~9V. That is as expected:
The yellow line is the CP signal and the purple is the contactor. Hence the relay activates, while the car is only applying enough resistance to pull the CP signal to 9V (which means connected, but no charge requested).
How can I solve this? The post from the old forum seems solved by help from a Victron staff member, so no obvious solution here.
I’m still pretty convinced that the car is doing what it should here, but I may be wrong. I do notice that the voltage is actually a bit lower than what I would have expected at 8.2V - 8.4V.
What are the threshold margins that the voltages can be off compared to the standard? And wouldn’t the auto calibration compensate for this?
While I was doing this test I noticed the charging station alerted my that a new firmware version was available (2.08), but I cannot find anything on it in the changelog document on Victron Professional (?). Nor does it seem to be publicly available yet.
@biggun_benny Let’s have a look at the charger when this is happening, can we do this next week?
I’m busy with an event this week, but next week , we can have a call and look at it
I’m having the same problem. Fiat 500e La Prima (42kwh) 2022. Firmware car is up to date. Tried a different charging cable, tried manually calibrating cp-line. Firmware EVCS is 2.08. Problem does NOT occur with other brand chargers. If the start/stop loop that occurs continues for a while, it trips the car in a way that a full system reset (disconnect 12v battery) is needed. The function “keep contactor closed after charging” prevents the loop, but it’s a workaround, not a solution. My guess is that the state detection voltages are either not according to spec, or too strict for real world application.
I have had a couple of talks with Lucian. He is very helpful. Last thing we ended up with was that maybe the ground connection in my house wasnt proper.
I had the electrician test it though and my ground is perfect. The issue even happened when I used the ground connection from my power company, but that didnt change anything.
Lucian said that he could see in the charger that the CP line once in a while was below 7V in one of the periods. This triggers the charger to start, which it should. But I also had my 100MHz oscilloscope on the CP line and there was no such low voltages.
I can only conclude that the Victron EV charger is extremely sensitive and starts charging instantly it see a period under 7V. Honestly, I think this would be easily fixed in firmware, and this is my recommendation for Victron.
All this said, the Fiats seems to function just on the edges of the CP line thtesholds and these two things cause this problem.
Both Fiat and Victron can fix this, but I think Victron are easier to persuade. Lets see if they look at these posts
