Hello, i have an ET112 meter connected to my cerbo all working fine.
The issue is i do not see it listed in the mod-bus register list, and need to add it to my yaml
code for displaying on the HA dashboard.
How would i go about finding the mod-bus slave & address of the meter?
The system is fully off-grid there’s no mains supply so no exporting. The ET112 is just used to monitor the house usage circuit.
Thanks…
try the ‘com.victronenergy.grid’ values (2600-2644)
You can also use the hacs victron add on
What @DuivertNL said you can get everything by using the HACS add on been working fine for me on the ET112 and the Victron VM meter
