I am trying to tweak the settings in VE config. I am set as ESS and in the assistant tab i have ess as an active assistant. In that assistant i have Battery system options, and mines is currently set as System uses lifepo4 with other type bms.
But above that there is an option System uses lifepo4 batteries with a two signal bms.
When i wired my batteries to the bms can port of the cerbo gx, i used can H and can L and ground on pin 456 on the RJ45 plug and it seems to be working on the current settings, but being i connected only 2 signal wires and ground, should i use the option "with a two wire bms?
No use other, description says CAN bms so thats the right one
