I have the Victron MultiPlus II 48/5000 GX with V3.66 software. I have a Basen Green LiFePO4 battery with CAN BMS. Currently, the BMS is set to Pylon (not Victron). The VE.Can (GND pin 3, CAN-H pin 7, CAN-L pin 8) is connected with a cable to the Basen Green battery (GND pin 7, CAN-H pin 4, CAN-L pin 5).
These are the VEConfigure screenshots:
I’m in the Charger tab and have selected LiFePO4 for the battery. Should I check “Configure for VE.Bus BMS”? Or not, since it’s connected to the VE.Can bus?
Here is a screenshot of the ESS assistant options:
System uses LiFePO4 batteries with a VE.Bus BMS
System uses LiFePO4 batteries with a two signal BMS
System uses LiFePO4 with other type BMS (this can either be a BMS connected via the CAN bus (e.g. a Lynx smart BMS …)
Which one should I select for a VE.Can BMS connection?
Overview of the settings I’m currently using in the ESS assistant.
This is another screenshot of the VE.Can bus:
Screenshot of VE.Can bus showing that TX and RX are increasing.
How do I get the VE.Can BMS working? The BMS should be connected to VE.Can and not VE.Bus, right? I’m asking because often people ask about BMS connection via VE.Bus.
What am I doing wrong? Thanks in advance for your help.
Best regards,
Mark
