Hallo Victron COmmunity,
I ordered a 5kwh battery from eel which uses a Seplos 100A BMS. I would like to configure an ESS with a Multiplus 2 48V 3000 GX.
I have two questions:
- What kind of network cable do I need to connect the BMS with the CAN Port of the MP2 (VE.CAN zu CAN BUS Typ A or B). Is there a detailed doc how to crimp the LAN cable? I am not sure what is needed for my battery.
- Are there recommended configuration settings for this battery?
Thanks for your support.
