Hi all,
I just finished my ESS system build:
- Multiplus II
- Cerbo GX MK2
- VM-3P75CT - connected via Ethernet
- Lynx Shunt VE.Can
I configured system as ESS (adding ESS assistant).
I now get an error GX Error #49 - Grid meter not found. In ESS setups with External Grid Meter selected, no meter was detected.
Multiplus is in passthrough mode (because it cannot find the grid meter)
The VM-3P75CT is visible in VictronConnect (local)
The VM-3P75CT was visible in VRM, before I added ESS assistant.
The VM-3P75CT is not visible anymore in VRM. Not sure anymore if this happened after I added ESS assistant or after I updated the firmware.
All devices are on latest firmware.
I have powercycled all devices.
Any clues how to fix this?
Thanks!
