Multi-RS Support for other than VE-CAN Gridmeter
Good morning.
Why does ESS not work with other than the VM-3P75CT Energy meter ?
I am an system integrator and in some cases it’s not possible to use these.
All our systems have a Cerbo GX, so this device can send the Gridmeter data to the Multi-RS we thought.
We want to use the Multi-RS more, but this is a game stopper.
Best regards.
Hi @dakoal,
in cases where a direct VE.Can connection is not possible, you can connect the VM-3P75CT to the same Ethernet network as the GX device and it will then proxy the measurement data via VE.Can to the Multi RS. 3rd party meters are not supported for the Multi RS.
Best
