Dear forum members!!!
After weeks of searching, reading and trying things out, I’ve had enough.
I can’t get the ESS to work as it’s supposed to (I think).
The surplus PV power should go into the battery once the grid is at 0, so to speak.
My problem is as follows:
The battery SOC is at 75%
ESS is set to Optimised without BatteryLife
An example from VRM:
PV yield: approx. 2,105 W
Household consumption: approx. 276 W
Battery charging: approx. 2,004 W
Grid import: approx. 282 W
Battery SOC: 75%
Why does it keep charging the battery instead of first bringing the grid to 0, so to speak, and then charging the battery with whatever is left over?
The strange thing is that it stops charging at 80%, and then does supply the house and tries to keep the grid at 0.
My installation consists of:
- Victron Cerbo GX
- 3 × Victron Multi RS Solar
- 4 × Pylontech 5000 battery modules
- Victron VM-3P75CT three-phase energy meter
- Communication between the Pylontech batteries and the Cerbo GX via CAN bus
The entire house is connected behind the AC output of the Multi RS Solar.
The grid connection is as follows:
Grid → Multi RS Solar AC input → Multi RS Solar AC output → entire house.
The VM-3P75CT is installed on the grid side and configured in the Cerbo GX as a grid meter.
What am I doing wrong???
Thanks in advance for your thoughts!!!
Regards, Wes
