VRM installation ID 850738, 3 Phase installation (MultiplusII), Ecoworthy 5-pack battery (25kWh), CerboGX, Smart Solar charger 250/60 DX-DX
Intention of use: Green home
Solar max up until today 14kWh against consumption 7-10 kWh
Expected: Use solar for home and loading battery, ad load from grid to top up battery when cheap (15 min. tarifs and max 36 hour prices known in the system). Use solar and battery when prices are high.
I can’t get it working this way, even today the system started loading the battery from grid at about 8:00 AM 1.27 kWh at the cost of € 0,24 while the soc of the battery is above 60% (system minimum at 35% and optimized minimum at 65% and electricity costs will drop to € 0,13 as from 11:00 AM.
I made changes the past days to ESS settings to optimised with battery live. Why, becaus since a few weeks the difference of soc per battery pack increased to above 20%. Because of that I started balancing the batteries for now on weekly basis and will prolongue to every 14 days.
Another behaviour that I noteced is that with sufficiant storage capacity in the battery pack available the algorithm seems to calculate on daily basis. So if today lowest price of € 0,10 and tomorrow € 0,25 today it doesn’t load additional energy in the battery for consumption the next day. It will load the next day the battery at € 0,25. How to correct this behaviour?
Since I’am a beginner any advise on how to approache the settings to realise my intended use is appreciated
at 9am that day - when the charging happened - you switched to the ESS Mode “Keep Batteries charged” - that basically disables DESS and charges your battery to 100% right away.
Other than that, I can see your system is nod discharging as expected - make sure you set the physical switch to “Inverter” rather than “Charger only”.
Last Note: You should not use BatteryLife along with DynamicEss. BatteryLife will increase your Minsoc by 5% eventually daily and that almost always goes along with the Scheduler then running short 5% usable capacity it was planing to utilize - and now has to allow from grid at undesired times.
If your system is quite new, you need to give the forecasts time to learn. The system would only buy from grid, what it assumes to need over available solar+battery within the next ~36h
So, if your battery is at a high enough soc with enough energy to cover your loads “till end of tomorrow”, it won’t buy anything, even if prices were 1 cent “today”. It does not “stockpile” energy it can’t see a forecasted need for.
Oke, than perhaps I should stop playing around and let the system find it’s balance. I somehow think I’am more clever so often tend to and correct the parameters in order to take as much advantage as possible from low energy prices.
Thanks for this advice and explanation on how the algoritm works. I start only watching the system doing it’s job.
After 2 months not playing with essential setting I noticed the following, the algorithm just loads to the expected SOC based on solar production against usage. This means that during the day at low energy prices (% 0,13-0,17) the system will not load additional energy to cover usage during the night but starts taking from the grid in the late night/arly morning at high energy prices (> € 0,35).
What I want the system to do is, with a minimum SOC of say 25%, load the batteries with excessive solar during the day as well as loading with low cost grid energy to say a level of 90%-95% SOC. This energy will be used to feed my home. This way I maximize self consumption of solar and reduce the energy bill substantialy because every day my solar production stays behind against usage.
Is it possible to arrange this with the current firmware of cerbo gx and what setting must I take care of?
Is it possible to configure the DESS setting so that I charge the battery to 100% SOC during the cheap hours (including solar energy), and then power my home from the battery during the evening/night/morning?
The algorithm starts charging during the cheap hours, but only up to an SOC appropriate for the expected consumption rather than to 100%. As a result, I have to draw power from the grid during the expensive hours every day.
I’d rather not use a schedule (fixed time), but base it on Tibber energy prices. Taking expected consumption into account, charging could also be postponed until the following day.
That’s exactly what the Dynamic ESS should do as well. Perhaps you could check again how you’ve set the electricity purchase and sale prices. It isn’t simply the online Tibber price; it’s calculated using a formula. This also takes battery degradation, etc., your learned consumption profile and the weather forecast for the following day into account. All of this allows the system to decide whether it’s cheaper to charge from the grid or from the battery. If that seems implausible to you, an input error in the parameters could have led to an incorrect prediction.
I entered the Tibber price correctly, including fees and VAT.
I have set the minSOC to 20%. If I leave the DESS to do its thing, I usually don’t get above 40% SOC. This then means that at night, power is drawn from the grid at, for example, € 0.34, whereas I could have charged the day before at € 0.14. If I factor in battery costs of € 0.03 and a round-trip efficiency of 82.8% for grid charging and discharging, this costs me € 0.20 per kWh—still cheaper than power from the grid.
So I would like the DESS to charge the battery to 100% on a daily basis, taking any excess solar power during the day into account, so that my total energy costs are kept to a minimum. If daily consumption uses, say, 30% of the battery and grid prices are high today but low tomorrow, there is enough capacity in the battery to wait until the following day before charging it to 100% SOC. On the second day, I would then be at 40% SOC, well above the minSOC
It may be that you think you’ve configured everything correctly, but in fact you haven’t. Have your dealer or Victron Support connect remotely and check it.
One possibility could be a faulty battery. If your SOC doesn’t go below 40%, then the battery wasn’t charged sufficiently. With each full charge, the SOC should drop by 5%. Perhaps the BMS isn’t happy because one of the cells is out of balance. Your dealer can check this via remote access and, if necessary, recognise it as a warranty claim.
Or do you mean that you only reach a maximum of 40%? In that case, you may have set a charging-voltage limit. This should be set automatically by the BMS.
Have you set Green mode or Trade mode in the ESS? In Green mode, my system sometimes feeds power equally into the grid and the battery. This is because, when the weather forecast predicts that tomorrow will be nice and sunny and the battery is not expected to run flat overnight, …
