Sorry for raising the risk of incompatibility with a delta-configured three-phase installation, but with new members we sometimes get some big surprises. As always, a diagram helps make things clearer.
Indeed, if there’s only one MultiPlus-II, I don’t see a problem.
As for the meter, it seems to me that the VM-3P75CT won’t be suitable because a neutral appears to be required for this meter, as is the case with those from Carlo Gavazzi (EM24, ET340, EM540).
Have you looked at the ABB B23, which is supported by Victron? It can be wired without a neutral. However, it connects via RS485. Nothing complicated. Why do you absolutely want an Ethernet connection?
