Error 25 on gxtouch
I recently put together a system for a customer with multiplus 2. 3000/12. Two smart lithium 12.8-200ah lithim batteries, cerbo, lynx bms, wakespeed ws500. i’m having an error 25 error refering to the wakespeed that repeatedly comes on on as an error notification. everything is up to date with most recent firmware. It only does it when the client has the van I can’t get it to repeat the error when I have it. Seems maybe something to do with bms pulling atc when batteries are full, but I’ve installed this exact setup a few times now and have not had this issue.
What exactly does the error code says?
Error Code#25 - and references the wake speed title from the device list
Can you make a screenshot?
Did you take look at the manual of the wakespeed device?
