Wakespeed not showing in Alternator Box
Wakespeed connected to Cerbo GX via Wakespeed to Cerbo Cable. Terminators installed on both Wakespeed and Cerbo. Charging just fine from Sprinter alternator. But it shows as Negative DC power. And not Positive Alternator Power.
When the vehicle is off the Alternator box disappears, so I know the Cerbo is “seeing” the Wakespeed, it just isn’t showing it correctly on the Touch. Any recommendations? See pics below.
What firmware are you on. I am on 3.50 and mine shows OK. Is it possible you need to have the WS500 setting for the shunt reversed. I am sure l have seen some other people mentioning this and Victron having made some changes causing this which needs to be completed in the upcoming V3.60 firmware. This is one reason I have stayed at V3.50.
3.54 firmware.
Re: The shunt. Are you referring to the Wakespeed shunt or the SmartShunt? I don’t believe either needs to be reversed, but maybe that might be part of my issue. I have both installed. The WS Shunt is in line with the 4/0 Negative Cable coming from the Alternator and then I ran another 4/0 to the Lynx Distributor. The Victron SmartShunt is then connected to the Lynx Distributor. The Current Sense wires for the WS are connected to the Wakespeed Shunt. I think this might be incorrect somehow.
Thoughts?
  1. I am referring to the WS500 shunt which is the one that sends tje alternator current to the WS500 and hence to the Cerbo. It is possible the sense wires are reversed, you can try the sense wires the other way or in the WS500 settings reverse the shunt direction, it is called is shunt backwards.
  2. I said above “I am sure l have seen some other people mentioning this”, i meant reversed current direction, even contacting Wakespeed who said it was Victron’s problem. Hence the point about waiting for new Cerbo firmware. As said, this is why I am reluctant to go above 3.50 at the moment.
  3. You could try the WS500 Facebook group, which is where this has been raised. WS500 group
Appreciate the help. I will do some more research. I did find the FB group and I will be reaching out to WS as needed.
Did you ever get a response to this issue? I’ve had the same problem and switched wires, removed other shunts, and moved the shunt around to attempt to fix the issue without success.
Have you tried installing the Wakespeed shunt on the Positive Line coming from the Alternator?
For info, I could fit my WS500 alternator shunt in the negative and that works OK.
Yes, I tried that too without any success.
So my issue was that the Negative of the Secondary Alternator and Chassis Ground shared the same connection point so my values were skewed. That coupled with a firmware update and updated programming on the Wake speed did the trick.
What battery are you using?
DIY (16) Eve 3.2v 280 amp hour battery cells connected in a 4p4s configuration to a Rec Active BMS. I was deep into this issue last year, but there was no fix and I could only find 1-2 posts online about it at the time. Felt like I tried every configuration moving around the Wakespeed shunt wires. Need to look again and re-update firmware (if available) for the Wakespeed to see if this now works.
And you used the configuration file on Wakespeeds Website?
I have exactly this problem (alternator showing up as a negative DC load) . Dis you manage to ressolve the issue?
