Hello everyone,
I have an EasySolar-II GX installed in a converted truck. At the moment, I’m parked on a plot of land with access to the grid, but about 1,200 meters away from the main electricity meter (the cable size and distribution panels were designed for this distance).
I wanted to test the ESS assistant without grid feed-in. To do that, I had to enter the country code (Grid), and since then I’ve been getting Error 11 – Grid relay test failed.
I can no longer connect to the grid.
It’s impossible to change this parameter again, even after removing the assistant.
I even tried to restore an old configuration file (.vsc) via VRM, but I keep getting the missing password message.
I really need to remove this setting, especially since I travel between different countries with my vehicle.
I don’t actually need the assistant — I only wanted to test it to see how it behaved, as I was planning to stay in one place for about six months.
Thanks in advance for your help!
If anyone has encountered this issue after adding a country code, I’d really appreciate any advice on how to properly disable it.
