What am I doing wrong?
I have a Energy Meter VM-3P75CTand a Cerbo GX currently, I turn off the grid about 5 hours ago. But I still showed up as it connected.
What kind of “grid” have you turned off?
The feed-in from the Multi itself or the entire grid feed-in for the system?
If you have only switched off the AC In from the Multi, the meter is still supplied and the power for your house continues to go through the meter … and is displayed.
The “Grid” is the shore power connection to the van, and it has been disconnected since yesterday. Even now, after so many hours, it is still showing as a flow on the VRM.
Hi. This might seem like a dumb answer, but try rebooting the Cerbo. Then do it again, yep TWICE.
If that doesn’t fix that ‘Realtime’ thing then it really is a dumb answer…
I’ll try later to day… Keep you posted.
