Anyone knows if there is planned patch for Easysolar II firmware related to ON/OFF scycling near max current. Seting limit to 80A is woraround shaving 20% of capacity. Or at verry least Victron sould get marketing correct and say its 90A chrager not 100A.
Like all specs, they are tested at 25C, the most common cause of “under-performance” is derating due to heat buildup or higher ambient temps.
Allready tested, unit is in Air Conditioned room. Setting even 16C wont fix it.
Regardless of settings it will enter ON/OFF loop, there are no errors, no warnings. Power just drops to zero for 10 sec, then starts ramping up. below 80A fully stable, above 90A its instant cut delivering less than 10% of power in average to battery. Between 80-90A it will modulate to deliver average 2500W to battery.
And on average i mean average of on/offcycles. This bug has ben there years, latest firmware still has it, there aremultipleposts about it but no solution. Only solution to “fix” is set change limit to 80A, then it works but essentially you are de rating your equipment 20%. Thats BS, if there is no fix just set model name to 250/80, then if people buy they know its 80A not 100A.
If you advert something and no plans delivering, its called a scamm. I get few precent error, but 20% is BS.
