Easysolar 2 gx 48/5000 230volt/GX device
I’m new to victron brand.
Can I use the integrated GX device to make my android tablet to a dedicated gx monitor? and how? do I need to add something? I know how to do it with the cerbo gx running venus OS 3.50 och higher.
Can I monitor my other systems at the same time with same gx device, by connecting them to same network? I have 48, 24, 12.
Or do I need one or two more gx devices and monitors?
My 48v battery is charged mainly by solar, but how does this easy solar unit work if I connect to shore power, can I safely connect to a 16amp outlet? I do not know if I ever would need anything more then charging winter time from shore power.
This is on a boat and usually all shore power outlets are only 16amp.
Charging the other banks is not decided yet what would be smarter a 48-24 DC-DC or another 230-24 inverter charger connected to the 230 side of the easysolar, from the 24v battery I probably go with 2x orion 24-12 converters as most boat equipment uses 12v but a few things need 24v.
Less important.
There is also the starter batteries for the engines that are 12v and will remain lead acid, everything else is Lifepo4
Yes you can use an andeoid as gx display, you can monitor different setups too, but you will have to change that in the app setup settings everytime
In vrm thats easier and you can use vrm on a android device too
