Hello, Victron community!
I have the following system configuration
Inverters: 3 × Victron MultiPlus-II 48/5000, three-phase configuration
Battery storage: 12 × Pylontech US5000, approximately 57.6 kWh nominal capacity
Solar array: Approximately 11.16 kWp, with east- and south-facing panelsʼ
Solar charge controllers: 2 × Victron SmartSolar MPPT 250/70
Monitoring and control: Cerbo GX / VRM
Electricity tariffs:
- Night (23:00–07:00): 2.16 UAH/kWh
- Day (07:00–23:00): 4.32 UAH/kWh
- Battery export to the grid: Not permitted
- Surplus solar export: Permitted
My goal is to charge the batteries overnight when electricity is cheaper and then use the stored energy throughout the day until 23:00, together with solar power, which is currently quite limited.
I have Dynamic ESS (DESS) enabled, but I’ve noticed several aspects of its behavior that I find confusing and frustrating.
1. DESS imports expensive grid electricity even when the batteries have plenty of charge.
For example, my battery SOC is around 80–85%, yet DESS decides to import electricity from the grid during the more expensive daytime tariff period.
Based on my own calculations, the available battery capacity should be more than sufficient to cover my household consumption until the cheaper night tariff begins at 23:00.
I don’t understand why DESS chooses to purchase expensive electricity instead of using the energy already stored in the batteries.
2. DESS does not charge the batteries sufficiently overnight.
Another issue is that DESS does not charge the batteries to a high enough SOC during the cheaper night tariff period.
As a result, the stored energy is not sufficient to cover my household consumption until 23:00, when the cheaper tariff begins again.
The batteries run low before the end of the day, and DESS switches back to importing electricity from the grid at the more expensive daytime rate.
I don’t understand why DESS doesn’t take better advantage of the cheaper night tariff by charging the batteries to a higher SOC, especially when this could help avoid expensive grid imports during the day.
