Dynamic ESS cannot be enabled while Oppotunity Loads is enabled. Disable Dynamic ESS first
Under ‘Settings > System Setup > ESS > Dynamic ESS’,
I see the following message:
‘Dynamic ESS cannot be enabled whilst “Opportunity loads” is enabled. Disable dynamic ESS first’.
I see this after updating the firmware to: V3.80~22.
My setup:
2x Multiplus-II 48/5000/70-50 in parallel.
Cerbo.
Smart-Shunt.
Canbus BMS.
What is this and how can I switch it on or off?
If you rollback to 3.73 does it work as expected?
Yes, the query/report has been resolved
Ok, thanks for confirming
Same issue here.
3phase multiplus 2 system
3.80~21
That seems like something slipped in there, that should not have gone into ~21.
The toggle for DynamicEss in the VRM Sidebar should be unaffected?
Yes, that’s right, this one works just fine
Why can the “opportunity loads” not be used together with Dynamic ESS?
On days, with dynamic prices like this, I would still like to use dynamic ESS.
The reason that they can’t be combined is that they sometimes can have conflicting goals.
